Sorry about that. Ugh!!!
My manual doesn't show a replacement procedure. However, the removal is simple, but the space available makes it difficult.
If there is access via the wheel opening, that is the way I would go. Remove the wheel and fender liner to access the pulley.
Next, remove the serpentine belt. Once that is off, remove the center bolt on the pulley/harmonic balancer. See pic 2 below. You will need a puller to remove the part from the crankshaft.
Reinstallation is the opposite of removal. I attached the torque specs below. (See pic 1)
Let me know if this helps.
See pics below.
Dec 7, 2022 at 4:17 PM
