How do you change the thermostat on a 2005 Chevrolet Colorado 2WD truck?
2005 CHEVROLET COLORADO
80,000 MILES • 3.5L • 5 CYL • 2WD • AUTOMATIC
DKOSCH
Cannot figure out to remove the existing thermostat and replace.
May 27, 2014 at 10:30 AM
You have to go through the bottom of the inner fender well. (driver's side). Once there, you have to use an extension on the ratchet with a swivel end to access the inner housing bolts. Have you located the thermostat?
May 27, 2014 at 11:04 AM
JDL
  • 16,098 POSTS
You get at it through the left wheel housing. Safely raise and support the vehicle. Remove the tire and wheel housing liner.
Number 4 in the picture is the thermostat housing.
May 27, 2014 at 11:05 AM
JDL
  • 16,098 POSTS
Hi jacobandnickolas,
I didn't see you, have a good day.
May 27, 2014 at 11:07 AM
