Hello again,
Edit: and some additional info, heater circuit ground to engine block ground is 2.6V, and sensor ground to engine block ground is ~17mV.
Something weird is going on..
If I measure from heater circuit + to battery ground I see 12V
If I measure from heater circuit + to sensor ground I see 6V
If I measure from heater circuit + to heater circuit ground I see 9V
Edit: below I did some possibly useless poking around related to the sensor ground:
So there should be a 6V difference between sensor ground and battery ground..
But If i measure from sensor ground to battery ground I see 0V. Does connecting a multimeter (+ to sensor ground, - to battery ground) somehow affect the circuit in ways I don't understand?
If I connect sensor ground to battery ground and force them to have a common ground I can then measure heater circuit to sensor ground at 12V..
It seems like sensor ground is floating somehow.. and when the circuit gets connected it goes back to common ground.
It also seems like heater ground is not what it should be.
Edit: I think I am going to try to see if there is continuity between the heater circuit ground and the pin it is supposed to connect to on the control module.
Do you have any ideas? this seems like its above my pay grade :'(.
Thanks again,
Konrad
Aug 17, 2019 at 7:39 PM
