I want to replace two motor mounts, (1) the Torque Strut Mount which is near the top of the engine on the passenger side, and (2) the Motor Mount which is near where the exhaust comes out of the front of the engine.
The Torque Strut Mount looks like it can be replaced without too much concern. The Motor Mount at the front of the engine is where I need help.
How do I support the weight of the engine to enable me to remove and replace the motor mount?
Also, the part currently installed appears to be aftermarket rather than OEM, and I plan to use the OEM part. The attachment shown in the picture indicates a bolt head at the top of the motor mount. The OEM part has threads and a nut. I hope the OEM part comes with the nut, or I will need to find one.
My key question is, how do I safely support the engine so that I can change the front engine mount?
Sep 3, 2018 at 4:56 PM
