Okay, I was able to replace the sensor, but the MIL light wouldn't go off after I cleared codes and disconnected the battery. Both wires to the VVT solenoid, also known as the camshaft position actuator valve, now fell apart. Can you maybe tell which of the color wires are pins 1 and 2 so I know which hole I can connect the pins back into the connector? The connector was also cracked so I am going to replace it with new pins.
Oct 2, 2022 at 10:23 AM
