How do I install a heated PCV assembly in my 1999 Ford van?
1999 FORD E-SERIES VAN
270,000 MILES • 5.4L • V8 • RWD • AUTOMATIC
DUTCHDUBS
Ford dealership says I need a heated PCV assy for my engine. It's the 5.4L V8 so the PCV connects from the back of the engine intake manifold at a 3/4" nipple down to the passenger side valve cover. However, there is an extra line coming off of that assembly. Ford-Parts.com shows a diagram of the hose going somewhere between the intake and throttle body but I can't make out where nor do I see ANY available ports at all for it to plug into. There are no coolant hose attachments as far as I can tell. Where does this extra hose go?
Mar 31, 2016 at 1:03 AM
HMAC300
  • 48,601 POSTS
here is pic of vacuum diagram of your engine. pcv is not electric not sure what you are talking about extra hose. it may go to air cleaner or valve cover maybe unless it is vacuum and then it should go to pcv
Mar 31, 2016 at 6:24 AM
