How do I fix a broken front window washer tube/pipe?
2005 HYUNDAI TUCSON
176,000 MILES • 2.7L • 6 CYL • TURBO • AUTOMATIC
KDB19
My front washer pipe has a 3 cm broken section at the top of the engine compartment on the right hand side. It looks a bit chewed. The pump works and rear washer works ok. The tubes in the hood/bonnet look ok and fluid ends up on the ground when I try to use the washer.
How do I find out the route of the tube so I can fit in a replacement section and what is the best and cheapest way to effect the replacement?
All help would be really appreciated.
Regards,
kdb
Aug 13, 2014 at 9:07 PM
Is it the rubber hose that is broken or a hard plastic? Can you upload a pic for me to see?
Aug 13, 2014 at 9:20 PM
KDB19
It's the rubber hose - attached is a pic of the bit that fell off
Aug 13, 2014 at 11:14 PM
You should be able to just replace the hose. For some reason, the picture will not enlarge when I select it, so it is hard for me to tell exactly what I am looking at.
Aug 14, 2014 at 9:26 PM
