My front washer pipe has a 3 cm broken section at the top of the engine compartment on the right hand side. It looks a bit chewed. The pump works and rear washer works ok. The tubes in the hood/bonnet look ok and fluid ends up on the ground when I try to use the washer.
How do I find out the route of the tube so I can fit in a replacement section and what is the best and cheapest way to effect the replacement?
All help would be really appreciated.
Regards,
kdb
Regards,
kdb
Aug 13, 2014 at 9:07 PM
