HERE'S THE KINDA PUMP HE IS DESCRIBING
THE JUG OF GEAR OIL IS WHAT MY JEEPS (CJ5 AND CJ2A) USE (DO NOT MISTAKE THIS FOR YOUR TYPE OF TRANSMISSION FLUID!)
PICS BELOW, THE PUMP IS ABOUT $5-$7 DEPENDING ON THE AUTO PARTS STORE
AS AN EXAMPLE, THIS IS MY '77 JEEP CJ5s 3 SPEED MANUAL TRANSMISSION, IT HAS A DRAIN PLUG ON THE BOTTOM AND A FILL PLUG ON THE SIDE, WHEN MINE STARTS DRIPPING BACK THRU THE FILL HOLE, I GIVE IT A COUPLE OF MORE QUICK SQUIRTS AND QUICKLY INSTALL THE PLUG.
JUST A NOTE: THE TRANNY IS NOT FULL!, THE CORRECT LEVEL IS AT THE FILL HOLE!
FROM THEN ON, IF I WANNA CHECK THE LEVEL, I GET THE JEEP LEVEL AND SCREW THE PLUG OUT, IF IT STARTS RUNNING OUT, I QUICKLY REINSTALL THE PLUG. ALL IS GOOD!
THE MEDIC
Apr 11, 2016 at 6:28 PM
