I went to pull out the ECM to check for codes by turning the screw on the back side. well when I was trying to get to that screw I must have pulled too much on the harness and broke a wire or pulled a wire out of the connector, because the car started before I did that and now it does not start. It will crank but not turn over. Any suggestions? Thanks.
Also, would you happen to have a wiring schematic of the ECM harness?
Jan 11, 2018 at 9:20 AM
