How can i fix codes P1135 and P1155
2000 LEXUS RX 300
99,230 MILES • 3.0L • V6 • 4WD • AUTOMATIC
ALEXRAY
Please how can i fix this, after i check the code.
1. P1135 it said air/fuel ratio sensor 1, bank 1-heater circuit malfunction.
Wiring, air fuel ratio sensor ECM.
2. P1155 air/fuel ratio sensor 1, bank 2- heater circuit malfunction.
Dec 27, 2016 at 8:10 AM
CARADIODOC
  • 34,306 POSTS
Oxygen sensors don't work until they're up to about 600 degrees Fahrenheit. They have electric heaters in them to get them there faster after engine start-up. To have the same fault code for multiple sensors suggests there's a broken wire going to those sensors.
Bank one and two refer to the two sides of the engine. Sensor one refers to the sensor in front of the catalytic converter.
Dec 29, 2016 at 3:19 PM
