hello, hoping someone can help? i have the vehicle listed above Grand Cherokee Laredo that i have been having blend door problems, all i would get is heat out of my vents, so after doing some exploring i found that my actuator was bad (a crack gear inside) so after replacing the actuator, i connected the new actuator to the connector plug before installing it, and i get no movement from the actuator, after
turning the switch from hot to cold, so my question is how can i check my A/C, Heat Climate Control switch. by the way i can move my blend doors by hand to change temperatures.
Nov 28, 2021 at 4:26 PM
