Okay. Just so we are on the same page, rotors get extremely hot when driving so they should be hot to the touch. I am not sure how your other vehicle's rotors are almost cold after driving it but that would be strange.
However, the purple-ish spots on them are called hot spots. That happens when the rotors get to hot. So if you have them on both front then you are having an larger brake issue or you are just a heavy brake user when driving? Do you drive more aggressively or are you very light on the brakes? Either way with time and mileage on this vehicle, I would take it into the dealer because it should still be under warranty. They will inspect the calipers and make sure you don't have a master cylinder issue. If so, they will fix it free of charge for you unless they determine it was caused by your driving.
Let me know what you think and we can go from there. Thanks
Sep 22, 2019 at 1:25 PM
