I have traced the wiring to here and found these results. I can't find any wiring diagrams showing where these two lines originate ..... at the computer??? But the lines are suppose to be 'hot'? Or from the ignition switch on the column? I seem to have had a few problems with that thru the years ...having to shut the car off...pull key and restart to eliminate the problem .... is that the computer or the ignition switch. Anyway, the power windows and a/c blower (which is stuck on - had to unhook compressor) do not work due to no power coming to the fuse/relay box. Where do these wires originate???
Thanks, Bl83687
Thanks, Bl83687
May 18, 2013 at 1:15 AM
