hot engine hard to start
1989 FORD AEROSTAR
225,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
MRCUTTY
Just had transmission rebuilt and new problem has occurred may be a coincidence, not sure. After driving approximately ten to thirty miles, oil pressure and temperature normal, no loss of either fluids, but attempted to start the van-turned over slow, started but shut off next attempt one slow crank did not start. Got battery jump drove to auto store and bought top line battery both old battery solenoid alternator and starter tested okay. Also wrapped starter with reflecting metal to keep starter cooler. Today after thirty mile trip, shut off engine for approximately ten minutes. Started slow, shut off, next turnover was slow almost nothing but it did start. I have used a head gasket sealer, no visible fluid loss of discoloration-seems like there is back pressure in the cylinder(s) when engines hot causing hard start. comments? John
Feb 24, 2018 at 11:29 AM
MHPAUTOS
  • 31,937 POSTS
I would get a current draw test done at the starter motor, it sounds electrical, may be. also, check all major earth points are clean and tight as well.
Feb 25, 2018 at 2:41 AM
It does sound like the starter motor this guide will show you what you are in for when changing it out.
Please get back to us.
Feb 27, 2018 at 3:30 PM
