Hot/cold air does not work all the way in front?
1999 CHEVROLET VENTURE
129,000 MILES • 2WD
KMKELSO81
  • 5 POSTS
Hot/cold air works in back but in front of works but doesn't blow like it should. It just barely blows air.
Nov 12, 2022 at 4:45 PM
If the fan is operating properly, have you checked the cabin air filter to make sure it isn't clogged?
The cabin air filter is located behind the glove box. If you haven't checked or replaced it, do this first and let me know what you find.
I attached the directions below.
See pics below.
Nov 12, 2022 at 10:43 PM
KMKELSO81
  • 5 POSTS
They do look like they need to be replaced. I took them out and it still didn't blow correctly. I'll get new filters....
Nov 28, 2022 at 2:30 PM
KMKELSO81
  • 5 POSTS
They do look like they need to be replaced. I took them out and it still didn't blow correctly. I'll get new filters. I don't know if it's different but it's actually a van....
Nov 28, 2022 at 2:32 PM
When you checked the airflow with the filters out, did you have the cover over where the filter was removed from?
Let me know. Also, let me know if the airflow directions are working properly.
Nov 28, 2022 at 8:29 PM
KMKELSO81
  • 5 POSTS
No, the cover was shut.
Dec 5, 2022 at 5:08 PM
The next thing I suspect is the mode door actuator is likely not getting the airflow actuators fully in position. Are you able to change airflow directions normally?
I ask because the actuators are engine vacuum actuated rather than electric. If the vacuum supply is weak or nonexistent, the doors will not move correctly.
If you look behind the controller, you will see a purple vacuum hose. Make sure it is fully connected and not leaking. That is the supply hose from the engine. If it appears good, remove it and start the engine. Place your finger over the end to confirm there is a good vacuum supply.
I attached the vacuum schematic below. Try this and let me know what you find. Also, with the engine running, see if you notice any hissing which could indicate a leak and note anything that appears disconnected.
See pic below.
Dec 6, 2022 at 1:56 PM
KMKELSO81
  • 5 POSTS
Is this the engine or under the passenger glove compartment?
Dec 9, 2022 at 1:17 PM
The pic above is of the controller in the vehicle. If you notice on the left side, it says the source. That goes to the engine intake manifold which is the source of the engine vacuum.
If you can locate the purple hose, disconnect it, and start the engine. Place your fingertip over the end of the hose to see if there is a strong vacuum being supplied.
joe
Dec 9, 2022 at 9:41 PM
