Okay, you can rent a set of gauges at a parts store or buy a cheap set at Harbor Freight for about $30.00. Then you can monitor high and low side pressures to see if the system is working correctly.
Is the line returning from the evaporator cold to the touch?
When you command the heat and cool, can you hear the blend door actuator moving back and forth? If it is stuck in the heat position, it will not allow cold air from the vents.
Jun 27, 2018 at 3:41 PM
