Hose keeps disconnecting
2004 VOLVO S40
90,000 MILES • 2.5L • 5 CYL • TURBO • 2WD • AUTOMATIC
CHRISTOPHER WILDER
See attached picture. This hose keeps coming detached and causes the car to shake and the brakes to be very hard to press. What is this hose for and how is it supposed to stay connected?
Sep 3, 2019 at 2:49 PM
CHRISTOPHER WILDER
Image attached.
Sep 3, 2019 at 2:50 PM
I need more pictures to tell what it is. but it looks like the retainer clip is broken. I can tell for sure if you upload more pictures of the connection and area. Please let me know.
Sep 4, 2019 at 6:48 PM
CHRISTOPHER WILDER
Images attached.
Sep 4, 2019 at 9:54 PM
Thanks for the pictures. this is for the fresh air system for the engine. I would use epoxy glue to put it back together. you should be okay. Let me know.
Sep 5, 2019 at 11:37 AM
JIS001
  • 3,412 POSTS
Yes, that hose goes to the electric vacuum pump for the brake booster. Does it pop out from the intake? Let me know. I have a good friend at Volvo in the parts department but you will need to send me the VIN number in a private message to see if the clip or the intake manifold needs to be replaced if the hose is popping off the intake.
Also send us a picture of the hose disconnected to see if the hose itself is damaged? You may just need the hose assembly. Will see if I can get you part numbers. I do some side work for his car and his family. Just depends on what mood I catch him in.
Sep 8, 2019 at 12:21 AM
