LOL. No problem whatsoever. I was thinking you were in a different country, and they still had a vehicle called a Citation.
The idea that it's a cavalier makes it a bit easier. Under the dash on the driver's side. You will see a larger wiring harness that goes to the fuse box. The relay is on a separate harness that will be attached to the main harness. I attached a pic below.
Let me know if this helps.
See pic below.
Jul 28, 2022 at 1:28 PM
