Horn Fuse is good (switched it with a known good one).
Horn Relay is good (switched it with a known good one).
When I press the center of the steering wheel, I can hear the relay click, so assume the switch is good?
Removed horns and tested them separate from the horn system and they both work.
Had the cable harness that plugs into the horn tested and it has twelve Volts output. Connections are clean.
Any idea what else could be wrong that I can try?
Aug 2, 2016 at 5:46 PM
