I just brought the vehicle listed above SLT model. i found out, the horn when pushed on doesn’t sound out. I check the fuse and relay and all are in good working condition. I asked a mechanic friend to check it out with his diagnostic scan tool by testing the horn and it works fine with the scan tool but won’t sound when pushed on the steering and that’s a safety issue. Than comes the next issue with the 3rd brake light or the high mount light as some call It not coming on when the vehicle is in ignition, but will come on when ignition is off when brake paddle is depress. That tells me the LED bulbs are not bad. And it follows with the next issue finding out the cruise control won’t come on when driving above the 40 miles. I parked the vehicle and press on the cruise control bottom, it came up on the instrumental cluster, but when I tried driving above the 40 miles to set the cruise control speed, it won’t engage. The rest of the switches on the steering wheel work fine except the cruise control switches.
Will this issues have anything to do with a bad airbag Clock spring or any other switches towards the brake pedal?
I have also scan the vehicle and the below are some results on the scan reader.
Please advise what steps to take in changing any needed parts.
Thanks,
Mo
Thanks,
Mo
Sep 24, 2021 at 5:34 AM
