Thank you for your response.
1. I need help in understanding the wiring connections on the relay (micro relay) mounted on TIPN circuit board. Have attached sketch.
2. Both horns sound with fuses removed and jumper wire from battery connected to horn side of fuse block.
3. Removed horn relay under TIPN cover and test with Ohms meter that read; 58 Ohms at coil and .3 Ohms at contacts.
4. The horn micro relay coil mounted on circuit board read 40 Ohms.
5. Would like to replace the Horn and Fuel Pump relay on TIPN circuit board being vehicle is a 2011 model. Need to research more how to.
6. Made Ohms test on connection 28, C7, to vehicle ground with horn “on” and “off”; No reading. Ohms test on connection 29, C7, to vehicle ground with horn “on and “off”; No reading. Ohms test on connection 28, C7 to connection 29, C7 with horn “on” and “off”; No reading.
7. Appreciate your support with this project.
Jun 26, 2019 at 4:58 PM
