Horn not working properly
2009 FORD FUSION
71,000 MILES • 6 CYL • 2WD • AUTOMATIC
The horn does not work when you push it but it works when you lock the doors and the alarm.
Jan 13, 2021 at 1:15 PM
This could be a number of things so we are going to need to run through this testing just to find out what the possible cause is. It could be a wiring issue, the clockspring, or the Smart Junction Box has failed.
Here is a guide that will help with this:
In most cases this is a clock spring issue so I attached the process on how to replace that as well.
Also, here is a guide that will help with this:
https://www.2carpros.com/articles/steering-wheel-clock-spring-removal
Let's run through this testing and we can go from there. Thanks
Jan 13, 2021 at 7:07 PM
