Hood will not raise
1999 JAGUAR VANDEN PLAS
72,000 MILES
GRAPPLER
Lever only releases one side.
Dec 26, 2018 at 9:52 AM
On the side that will not release have a helper push down on the hood while you are releasing it. This should take the tension off and allow it to open. Once open adjust the cable or lube the latch to the side that is not opening. I would lube both sides. If that doesn't work you will need to carefully lift the side that released until you can get something in to manually release the other side
Dec 28, 2018 at 9:58 AM
