Honda starts and when driving it cuts
1996 HONDA BALLADE
1.5L • 4 CYL • 2WD • MANUAL
PHILLIP1960
Honda starts and when you drive it, it cut you can when check everything when it starts and do the same. Honda 1996 150i 15D3B Engine
Feb 28, 2014 at 2:27 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuelpressure with agauge in U.s. autoparts rent hem
Feb 28, 2014 at 9:36 AM
PHILLIP1960
It do not have a computer box -, it only have electronic ignition. If I drive the car it goes fin and then the rev counter cut out and then after the engine. If you wait 2 min you can start it and go again, and then it do the same
Feb 28, 2014 at 10:17 AM
HMAC300
  • 48,601 POSTS
we do not have that model in the U.S. but it still should have a computrebox. If not have the electronic ignition checked as a module or pickup coil may be bad. also check your fuses underhood as well as your main relay
Feb 28, 2014 at 12:01 PM
