Purchased a Used Ridgeline recently from a wholesaler. Discovered after purchase, that it was in a collision with airbag deployment. Not sure the extent, but Honda says the repair was done well. Truck seems to run perfectly with no frame damage.
Want to reassure myself that all systems such as VSA, ABS, Airbags are all working correctly after the repair was complete. All the warning lights go on and off after ignition is turned on, as they should.
Question:
Is this enough to say that all systems are OK or is there a diagnostics test I can have done that will ensure it's working as it should?
Question:
Nov 12, 2006 at 4:32 PM
