I searched all over the net for someone who has had this problem, and i have found multiple sources that talk about some of the same symptoms that are associated with a code 43 ie, bogging, powerloss, stumbling, idle problems, horrible gas mileage (even on 100 octane).
I have had my prelude (92 Si, H23 5 speed) for about 6 months now and I have repaired many things that were throwing codes, and now the only one that remains is the code 43.
Here is a list of the things that I have repaired.
1. O2 sensor(new)
2. Knock sensor(used but not coding)
3. Map Baro sensor(used but not coding)
4. Cap (denso)/Rotor(denso)(new)
5. Plugs(denso iridium)/wires(OEM)(new)
6. Fuel filter(denso)
7. Cat(new)
Total cost: about 500 bucks from various sources.
Other repairs
8: Exedy Stage 1 clutch
9: Custom Racing axles (clutch snapped the oem pair, prolly bad cv joints to begin with)
10: Pro-Lite aluminum flywheel
11: 2.5 in electric cut out (Pre-cat)
12: Intake
13: Seafoamed
14: Fuel system treatment.
The car ran alot better for a long time and i never pump anything but 93 octane, but it still had the problem of once it warmed up it started running like crap, and i would and still do get this smell, its kind of like a caustic sulfur smell, when the car would get really warmed up or on a hot day. Sometimes after a high rev session the car would stall out. this is frustrating because I love the car other then this problem. help me oot if anyone has a solution to this.
oh yea one more thing i forgot to mention. The car runs with a higher idle, 2k, i figure its normal since the car is warming itself up. But after a little while it will seem to warm up, then the check engine light will come on and the idle will drop to around 900-1100 rpm. dont know if thats related to the code 43 but i figure any info is helpful in coming to a diagnosis.
I just took my car to get smogged here are the results
HC- MAX 91 MEASURED- 634
CO- MAX 0.62 MEASURED- 12.87!!!
Everything else is cool.
Its running pig rich and the timing is all fkd up. I hope its the distributor only and not a leaky fuel injector or something...let me know..
:twisted:
1. O2 sensor(new)
7. Cat(new)
Other repairs
12: Intake
13: Seafoamed
:twisted:
Oct 25, 2006 at 2:06 AM
