i have a 1996 honda prelude si 2.3 obd2 and i put an obd1 1992 honda prelude si 2.3 and i have spark only one time every revolution in the distributor there is only one pickup in the distributor is that all that is suppose to be in there i have an external coil and crank sensor i had installed the crank sensor with the original 96 oil pump and houseing on the 92 block i just cant figure out why the spark is like that timeing has been checked out and coil and cranksensor all check out would egr valve have any effect or was i suppose to convert my ecu wich i live in ny and is impossible to do and pass inspection please help im in a jam-thank you .
Jan 25, 2007 at 10:22 AM
