99 Honda prelude 5 speed - can't shift into reverse??
1999 HONDA PRELUDE
HONDARULES
He Guys,
Question ... I just purschased a 99 Honda Prelude 5sp with 66k.
It was checked out before I purschased; however, like anything mechancial things happen. It was one owner and records indicate that theClutch Master Cylinder was replaced at 60k. The car has been running very good;however, last night when I was leaving the store I couldn't get it to shift into reverse ... gears 1 - 5 work fine , but it won't let me shift into reverse. Could you provide some advise/suggestions before I bring
it to the local garage (they are very good, and do excellent work, but costly) and I want to ensure I know what should or should not be checked.
YOur help and advise is appreciated!!!
Jan 21, 2006 at 7:12 AM
2CARPRO JACK
  • 11,533 POSTS
might be a shifter problem if all else works ok.Try 4th then reverse with engine running
Feb 13, 2006 at 5:06 PM
