I just picked up an 84 Prelude from a friend for free, that has been sitting for 4-5 yrs. I'm in Dyer need of a work car so I would really like to get it running... My question: Is there anyway I can fix the compression without taking the motor apart? It has spark, gas getting to the carbs and still wont fire. I talked to the local Honda Shop and he said check the compression and it should be a minimum of 120 to run. I held a tester on each one and used a remote starter and the most I got was About 40 Psi. and the least was 5-10 Psi. with the throttle open and closed. can you help me please...
Thanks T.L.
Thanks T.L.
May 24, 2007 at 10:53 PM
