I have no spark at spark plug 1, pulled spark plug out grounded turned engine over no spark. Tested wires going to coil as manual stated battery volts at blkyellow. tested resistance at coil test like manual said a to sec winding tested 18.9 ohms ok. a-c tested 0 ohms manual said .64 to .78 went to Autozone and tested new coil same results. Tested ICM unit tested ok. Tested wires 12v at black and yellow. tested countinuity as far as I could in engine compartment. could follow back all the way to ecm couldn't find plug as discribed in manual. I have new plug wires. resistance good. I have 12 volts coming out the end of the coil. Checked all fuses all good. Car was stored for 5 years and only driven for 1 before storage. Need to know next step to track problem down. I am willing to donate $10.00 to start. I am not sure how this all works but if you stick with me until I solve the problem I will donate another $20.00
May 2, 2009 at 8:20 PM
