Was alerted to an EGR problem by the engine light and corresponding fault code which I downloaded.
I have tried the following cures recommended by the service manual with no success.
1) Removed, cleaned, and re-installed the EGR valve with a new gasket. Cleared the fault register but the error came back again after several minutes of driving.
2) Removed and tested the EGR valve to find that it was faulty (failed resistance test). replaced the valve with a new one but again the error came back after several minutes of driving (it took longer this time for the error to return- 20-30 minutes).
3) Removed the new valve and tested it. Found that the new valve failed the resistance test.
4) Performed a vacuum test on the valve and the surrounding vacuum lines. All were ok.
Any help would be appreciated.
Aug 24, 2007 at 11:14 AM
