I'm having a problem w/ the clutch when you step on the clutch it goes all the way down but won't come back up after replacing the clutch. I bled the system, replaced both the master cylinder and the slave cylinder (doesn't use wire it's self adjusting). The clutch is still the same... I took off the tranny off and checked the clutch, bearing, and fork they all look good. Could you point me in the right direction, thank you.
May 12, 2008 at 12:48 AM
