1997 Honda Prelude Replacing Power Steering
1997 HONDA PRELUDE
142,000 MILES • 4 CYL • 2WD • MANUAL
DJO_07
My power steering hose leaks, making it hard for me to be able to steer. So i need to know as much information as you can give me on how to replace my old p.s. hose one with my new one.
Jun 27, 2008 at 3:41 PM
KHLOW2008
  • 41,814 POSTS
Hi djo_07,
1. Remove joint at pump, 2 pcs 10 mm hex bolt.
2. Remove holding bracket at intake manifold.
3. Remove hose clamp on crossmember.
4. Remove pressure switch connector on hose.
5. Use 14mm hex pipe spanner to remove pressure pipe hose joint at steering box valve body.
6. Use your imagination to figure how to get the hose out and new hose in again. ;)
Jun 28, 2008 at 10:42 AM
