1996 Honda Prelude window motor
1996 HONDA PRELUDE
AFLOR080
  • 16 POSTS
Electrical problem
1996 Honda Prelude 4 cyl Manual 190000 miles
the passenger side window stopped working so i thought it was the motor so i replaced it but im still not getting any power could it be the switch and is there a fuse that going to the window lift motor that could be it. thank you
Aug 17, 2010 at 1:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
there is no separate fuse for each window motor, just one for both together. could be the switch or just wiring to the motor. check for power at switch.
Aug 17, 2010 at 5:02 PM
AFLOR080
  • 16 POSTS
would the fuse stop both side from working cause the driver side that controls the passengerside window wont do anything it only raises the driver side and how can i check the power to the switch
Aug 17, 2010 at 7:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if it can raise the window than fuse is good. seems like the driver side master switch is at fault, if it fails than neither switch will work.
Aug 17, 2010 at 9:13 PM
