1996 Honda Prelude hard to shift gears
1996 HONDA PRELUDE
161,000 MILES • 4 CYL • FWD • MANUAL
BUGEYEDBOOGER
I haven't drove my car in about 3 months. its cold weather now and aroun 30-40 degrees. i went to drive it and push the clutch down and it felt real spongy and it did not want to go into gear as easy as it should. so i drove it to my destination and it was hard to put it in all the gears but manage to get it in gear without forcing it. i left my destination 3-4 hours later and i shifted into gear easier than earlier that day. is there a minor transmission fluid problem or major clutch repair problem or is it the cold weather not driving as often problem?
Jan 13, 2010 at 6:47 PM
KHLOW2008
  • 41,814 POSTS
Hi bugeyedbooger,
It most probably is the clutch hydraulic system. Did you check the clutch fluid level?
The cold weather could affect a weak hydraulic system. Parking for extended periods is another factor.
Jan 16, 2010 at 12:33 PM
