1996 Honda Prelude clutch
1996 HONDA PRELUDE
KEITH DONNELLYL
Transmission problem
1996 Honda Prelude 4 cyl Two Wheel Drive Manual
my clutch seems to have failed.pedal has lost all pressure it happened over night without warning
Jan 11, 2010 at 8:58 AM
KHLOW2008
  • 41,814 POSTS
Hi keith donnellyl,
Check the clutch reservoir fluid level.
The hydraulic system has failed and it should be due to a leakage either at the master cyliinder, slave cylinder or the hydraulic lines.
If it is a minor leak, topping up the fluid and bleeding the the system can get you some mileage to get the vehicle to the nearest place for repairs.
Jan 11, 2010 at 11:53 AM
