Hi there,
You will need to remove the door trim and check the power supply to the motor, if the supply is OK the motor will be faulty, if no power check that the switch is functioning correctly, if you don't feel up to doing this your mechanic can check this in about 1/2 Hr.
Mark (mhpautos)
Oct 27, 2008 at 8:31 PM
