1994 Honda Prelude misfire
1994 HONDA PRELUDE
196,000 MILES • 4 CYL • FWD • MANUAL
DEEPBLUEMAKO
i just change out the spark plugs and spark plug wires and my car started missing a cylinder and then it will fire the cylinder after awhile but the problem is getting worse
Apr 20, 2009 at 1:43 PM
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Apr 20, 2009 at 2:58 PM
