Engine Mechanical problem
1994 Honda Prelude 4 cyl Front Wheel Drive Manual 0
I bought honda prelude with a h23 engine that had 2 bent valves in cylinder 1 So i got a valve job done and the head resurfaced and 2 new valves. So I put the engine back together and it still had no compression in cylinder 1 and now cylinder 3 only has 60 PSI when cylinder 2, 3 and 4 had160.
When I start the engine it runs really rough and shakes and has 60 PSI in cylinder 1 only when running. Also before I put my head back together I saw that there was some rough marks in the cylinder walls so I honed them out and sand it down a little to make it smooth, would that have something to do with it? Maybe I took too much off so the piston isn't getting a tight fit? Or maybe the head gasket I bought is for a h22 instead of a h23?
So im thinking that the piston ring is bad or something, have an idea on how much it would cost to get the block rebuilt with new pistons or have any ideas?
I tried putting oil in the cylinder to see if maybe it had a stuck piston ring but it didn't do anything.
Also thought maybe the timing was off by a tooth or something but the timing is perfect.
Feb 22, 2009 at 9:50 PM
