1993 Honda Prelude Oil Overfill - Idle problem - will not s
1993 HONDA PRELUDE
200,000 MILES • 4 CYL • 2WD • MANUAL
PRELUDEKENT
My oil was overfilled. I drove it about 30 miles after that. During that time the idle began to surge with the clutch in. Also, car seemed to have to have the cooling fan run after the engine was shut down, for extended time periods. There was never a CEL or code registered.
Eventually, car will no longer start. It cranks but does not begin running.
I replaced the fuel filter, rotor and cap, plugs and checked all wires, coil and ICM. I also replaced the PCV valve.
Of course, I drained the oil to the proper level after I finally realized the overfill was a problem.
What should I do now?
Apr 2, 2010 at 11:23 AM
KHLOW2008
  • 41,814 POSTS
Hi preludekent,
Check the coolant level in the radiator. Seems the engine was running hot and hope you have not damaged the head gaskets.
Apr 10, 2010 at 10:49 PM
PRELUDEKENT
Thanks for your reply. The coolant was low. I added 1 gallon of 50-50 to get it full again.
I did a compression test, on the cold engine.
1: 187 psi
2: 194 psi
3: 175 psi
4: 185 psi
There is an oil leak, I think from the oil cooler that leaks only when you crank the engine.
1. Do you think the oil cooler is where I'm leaking the coolant into the oil?
2. Do you think the compression test proves that the head gasket is ok?
3. If the source of the coolant / oil leak is fixed, what is your best guess of other problems? Will I need to do more to get it started?
I've made my mechanic rich over the last few years, and have vowed to take care of this myself or just ditch the car.
Apr 12, 2010 at 6:50 PM
