1993 Honda Prelude hard to shift
1993 HONDA PRELUDE
DEVIN4554
Transmission problem
1993 Honda Prelude 4 cyl Front Wheel Drive Manual
hey, I have a 93 honda prelude h23a manual trans. it has about 260000 miles. it drives fine but then sometime when i get in and start it up and try to back out my drive way it or shift to 1st gear it wouldn't even move in any gears, its weird because it would be driving perfect and shifting smoothly then all of a sudden when I cut it off then crank it back up it wouldn't want to shift in any gears. so i roll it down the hill and force it into 2nd while i mash on the clutch and give it a little gas and all the gears are live that, then after a while of driving it like that. after a while of drivin it like that it begans to shift smooth again. my clutch is good , my fluid is good, cylinders good. does this sould like a shifter problem or shift linkage and why would it all of a sudden act like crap then work fine again?
Feb 17, 2010 at 5:33 AM
KHLOW2008
  • 41,814 POSTS
Hi Devin4554,
Need to understand the rpoblem better.
When you mention unable to move in any gears, does it mean you are able to shift into gears and it is not moving?
Wouldn't want to shift into any gears? Not able to move the shift lever?
Can you shift into any gears when engine is not started?
Feb 18, 2010 at 10:36 AM
