1993 Honda Prelude
1993 HONDA PRELUDE
REDROSE36
Engine Mechanical problem
1993 Honda Prelude 4 cyl Two Wheel Drive Automatic
when I was sitting at a stop light the engine sqeeked and the it died and the I started it back up and then i died again and now it won't start at all
Sep 3, 2008 at 2:29 PM
KHLOW2008
  • 41,814 POSTS
Hi redrose36,
You need to isolate the cause of the problem.
1. Check/test for sparks at plugs when cranking.
2. Remove air intake hose and pump some starting fluid into throttle body and try to start.
Test for fuel pressure at fuel rails.
3. Do a compression test if both the above don’t work. It could be a broken timing belt。
Sep 21, 2008 at 10:57 AM
