1992 Honda Prelude burns oil
1992 HONDA PRELUDE
147,000 MILES • 4 CYL • FWD • MANUAL
RAINVILLE
HI-
My 92 prelude omits blue smoke when I give it a lot of gas. The check engine light is also on. I know sometimes the check engine light is due to a vac leak but could this also cause the motor to burn oil or is it a bigger problem like rings. I have not done a compression test yet.
Apr 30, 2008 at 5:23 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You should do a compression test as the oil burning will more than likely be due to worn rings.
mark (mhpautos)
Apr 30, 2008 at 5:29 AM
