1991 Honda Prelude trottle pulse at idle
1991 HONDA PRELUDE
190,000 MILES • 4 CYL • 2WD • MANUAL
BGEEZY
my 2.1 si prelude has an issue when it idles it jumps from 600 rpms to 1500 and some times all the way up to 2200 rpms ive been told its a throttle position sensor and also a fast idle valve. what do you know about this issue? apparently the "TPS" cannot be replaced without getting a whole new throttle body and if thats the problem is theyre a way around that
Jul 20, 2010 at 9:43 PM
Your 1st step here should be -check and test the EACV and Fast idle valve before the TPS The idle speed of the engine is controlled by the Electronic Air Control Valve (EACV), located on the intake manifold between the throttle body and the fuel injector rail, and the fast idle valve.
https://www.2carpros.com/forum/automotive_pictures/12900_eacv_2.gif
Jul 21, 2010 at 6:18 AM
