1991 Honda Prelude timing belt
1991 HONDA PRELUDE
TRUDICKS
Engine Mechanical problem
1991 Honda Prelude 4 cyl Front Wheel Drive Manual
What happens when the timing belt brakes
Jan 7, 2010 at 8:55 PM
PEAR69
  • 1,482 POSTS
It depends on the timing position of the camshafts. A broken timing on your engine can bend or break valves, damage pistons, scrape cylindef bores, break camshafts..If the timing belt on your engine has broken - it is best to at least remove the head to check and see if any damage is done to the tops of the pistons - check the valves ETC..Don't just replace the timing belt (if it breaks) because you can do even more damage...
Jan 8, 2010 at 1:05 AM
