1990 Honda Prelude starting
1990 HONDA PRELUDE
120,000 MILES • 4 CYL • FWD • MANUAL
SKWERRUL
my car suddenly wont start... battery is charged fully and new, alternator two years old and works great... already replaced the starter, ignition switch, and ignition cylinder(whatever you call the piece you put the key into)... no sound at all under the hood...
May 15, 2008 at 8:09 PM
KHLOW2008
  • 41,814 POSTS
Hi there,
Your problem should be an open cranking circuit. Check and see if the starter solenoid wire is seated properly or not. You need to check for current supply to solenoid with ignition switch in cranking position.
Btw, check and see if the earth strap is broken or not, the one from the battery to the transmission.
May 25, 2008 at 8:31 AM
