1989 Honda Prelude Runs on 2 cylinders.
1989 HONDA PRELUDE
175,000 MILES • 4 CYL • FWD • MANUAL
HIGHWAYSTAR
  • 4 POSTS
After replacing the distributor cap and rotor the car ran fine for about five minutes (2 miles) and then started missing and wanted to die. It would not idle unless the throttle was kept slightly open. I checked the cap and rotor, wires and replaced the plugs (as they were fouled and 1 & 2 were wet). Everything checked out. The engine ran only on 2 clyinders (3 & 4) as I checked the plugs again (1 & 2 wet and 3 & 4 sooty). The "check engine" light did not go on and there are no codes on the ECU. Please advise.
Oct 25, 2009 at 12:53 PM
BMRFIXIT
  • 19,053 POSTS
Do a compression test on all cylinders
check if it sparking on all cylinder s
let me know
Oct 25, 2009 at 7:09 PM
HIGHWAYSTAR
  • 4 POSTS
Thanks for your response. All the cylinders are sparking. I did not do a compression test as I do not have a deep gauge or attachment to check it. That is the last thing that I suspect anyway. I do notice that cylinders 3 & 4 that do run are very sooty. Also, when I pull the plugs out of 1 & 2 they are quite wet with gas. There seems to be too much gas delivered for some reason. Still no "check engine light" or computer codes. What do you think?
Oct 28, 2009 at 8:14 AM
BMRFIXIT
  • 19,053 POSTS
With out a compression test
I would switch one of the injectors and check if the problem move with it
Oct 28, 2009 at 6:40 PM
