1989 Honda Prelude engine revs to high
1989 HONDA PRELUDE
250,000 MILES • 4 CYL • 2WD • MANUAL
SQUIIZY
  • 4 POSTS
when my engine is at operating temp. the revs are 1000. on warm up revs at 1500rpm.
have had new head rebuild over 12months ago.
all lincages and engin in very good condition....
How do I bring down idle to 700rpm.
the engin is injection model. 2000.
thanks squiizy... I am just a poor boy.....
Oct 12, 2010 at 12:57 AM
Check and test Electronic Air Ctrl. Valve (EFI) On top of engine, look for vacuum leaks also might try dropping it down using the throttle stop screw
Oct 12, 2010 at 2:06 AM
SQUIIZY
  • 4 POSTS
Razy......There is no throttle down skrew on my fuel injection engin.,......
I can resolve the idle by way of the computer but to expensive and reves are to close to the normal retting od 750.
I have heard that I can reverse the spring loaded cap in the EFI valve. this will bring down the reves permanently which is ok for a warm climate.
all other points on my car are excelent.
I have disconected the EFI with the reves coming down to 600. this is good for a manual change. but the warning engin light stays on and the air con. won't come in due to the reves being low..... will this be ok.to reverce cap,.. squiizy.
Oct 12, 2010 at 10:23 PM
Try adjusting the idle speed thru here
https://www.2carpros.com/forum/automotive_pictures/12900_honda_7.jpg
Oct 12, 2010 at 10:28 PM
SQUIIZY
  • 4 POSTS
Razy; I have adjusted this screw right in with reves still high..... I thought this was cutting down the fuel flow. sorry; squiizy
Oct 12, 2010 at 10:39 PM
Did you double check for vacuum leaks-try checking the TPS sensor voltages-see below
https://www.2carpros.com/forum/automotive_pictures/12900_tps_30.jpg
Oct 12, 2010 at 10:46 PM
SQUIIZY
  • 4 POSTS
I will try all your suggestions.... thank you very much for your help...... Squiizy.......
Oct 12, 2010 at 11:15 PM
You are very welcome, TY and GL rasmataz-
Oct 12, 2010 at 11:17 PM
