1988 Honda Prelude Water Pump Replacement
1988 HONDA PRELUDE
PRELUDE18
1988 Honda Prelude 4 cyl Four Wheel Drive Manual
Can you please tell me how to change the water pump?
Aug 3, 2008 at 1:57 AM
KHLOW2008
  • 41,814 POSTS
Hi prelude18,
To explain the process of replacing the water pump is not easy and I would suggest you get a repair manual if you are really interested in DIY.
Aug 3, 2008 at 12:31 PM
PRELUDE18
Thanx for your response i have the 88-91 B20A-6 engine maintenance and repair manual however it has nothing in it about the water pump
Aug 3, 2008 at 5:55 PM
KHLOW2008
  • 41,814 POSTS
Hi prelude18, To replace the water pump, you need to remove the pulley and belts. Loosen timing belt cover and the water pump can be taken out after the retaining bolts are removed.
https://www.2carpros.com/forum/automotive_pictures/192750_Accord88Waterpump_1.jpg
Aug 4, 2008 at 7:31 AM
